O que é fácil:The weapons simulation in the game takes into account the following:
1) Muzzle velocity (meters per second velocity at the moment round departs muzzle)
2) Weight of the round (muzzle velocity plus round weight equals kinetic energy at the moment of impact)
3) Weight of the explosive charge (chemical or explosive energy)
4) Round metallurgic composition (ie. what the metallurgy of the round is, which translates into hardness of the metal and ability to penetrate)
5) Rate of fire
6) Dispersion (effect of vibration due to movement of the mounting during firing and flight on the accuracy of the round)
7) Gravitational effect (ie. speed at which the object falls towards the earth's center after leaving the muzzle)
8 ) Drag effects (rate at which the velocity of the round decays)
9) Type of explosive used in the round (ie. nitro cellulose, tnt, etc. each rated for their explosive power)
10) Weight of the complete cartridge is also modeled, (in addition to the weight of the fired round) so the aircraft weight can be adjusted down as cartridges are used
11) Weapon jamming is not modeled, although no doubt it could be if we wanted, and may be incorporated in later TF mods. (the wingmount MG/FF was prone to jamming when fired in other than level flight, especially when fired in high G situations as for example, high G turns to allow deflection firing. In contrast, the Browning .303 and MG17 were not prone to jamming in these situations)
12) Round fusing... ie. how many seconds after an HE round is fired the fuse will cause the round to explode.
All of the game weapons are based on the real life weapons.
I would recommend anyone who is so completely unsatisfied with the way the weapons currently function create their own mod.
// Concussion --- ôóãàñíûé
// Fragmentation --- îñêîëî÷íûé
// Thermal --- çàæèãàòåëüíûé
// HollowCharge --- êóìóëÿòèâíûé
// Electromagnetic --- ýëåêòðîìàãíèòíûé
// Antimatter --- ðåàêöèÿ àííèãèëÿöèè
// Nuclear --- ÿäåðíûé
// òèïû Â.Â. áûâàþò:
// TNT --- òðèíèòðîòîëóîë (òðîòèë)
// Amatol --- àììîòîë
// AmmoniumNitrate --- íèòðàò àììîíèÿ
// ANFO --- ÀÑÄÒ
// BlackPowder --- äûìíûé ïîðîõ
// C4 --- C4
// CompositionB --- ãåêñîãåí-òðîòèëîâàÿ ñìåñü
// HMX --- îêòîãåí
// Nitroglycerin --- íèòðîãëèöåðèí
// NuclearCharge --- ýêâèâàëåíòíûé òåðìîÿäåðíûé çàðÿä
// Octanitrocubane --- îêòàíèòðîêóáàí
// PETN --- ïåíòàýðèòðèòòåòðàíèòðàò
// RDX --- ãåêñîãåí
// Semtex --- ñåìòåêñ
// Tetryl --- òåòðèë
// Tetrytol --- òåòðèòîë (òåòðèë/òðîòèë)
// AntimatterCharge --- àíòèâåùåñòâî
// Phosphor --- ôîñôîð
// Gasoline --- áåíçèí
