Patch 4.04 lançado...
Wolfox
Post by Wolfox »
Oi pessoal...
Aparentemente foi liberado hoje um novo patch pro PF, corrigindo alguns bugs da versão 4.03. Aí vai o link no site oficial:
http://www.pacific-fighters.com/en/updates.php
Um abraço a todos.
32_Mariocar
Post by 32_Mariocar »
Obrigado pela informação Wolfox, parece que estão corrigindo alguns problemas com placas ATI, e também no Mosquito.
Mariocar
Wolfox :ok
Espero que tenham melhorado mesmo o Mosquito. :roll:
01_Urubu
Post by 01_Urubu »
Valeu Wolfox :ok
README
Pacific Fighters v.4.04 (4.04m)
Warning
The current version 4.04 (4.04m) is not compatible with the previous versions of the sim when playing over the network (Online). Both the server and client must have the appropriate versions in order to connect.
For your convenience, we have introduced different version numbers for the stand-alone installation and the merged (FB+AEP+PF) install.
4.04 – for stand-alone PF
4.04m – for merged (FB+AEP+PF)
Attention: versions 4.04 and 4.04m are not compatible with each other when playing over the network (Online).
Add-On Installation Instructions (Please read carefully)
The 4.04 free add-on installs only over 4.03 (PF stand alone).
The 4.04m free add-on installs only over 4.03m (FB+AEP+PF merged).
In order to install this free add-on, run the following:
1) For Stand alone: PF_patch404.exe and follow the on-screen instructions.
2) For Merged: PF_patch404m.exe and follow the on-screen instructions.
Please note that the merged version of Pacific Fighter will get all additions and features that are listed below, while the stand alone installation will only get the Pacific Fighters-specific ones marked by ‘*’.
Modifications and fixes
1. Implemented work arounds for some ATI & NVIDIA drivers bugs.*
2. Fixed a bug with Mosquito damage modeling.*
3. Patched up a hole in the Mosquito cockpit.*
4. Reversed the gear indicator light in the Do-335 cockpit
5. Fire extinguishers added to the Mosquito.*
6. Corrected some bomber formation AI.*
New ground objects:
New ship – PAM (Hungarian)
Additional Notes:
If you have a computer with a Pentium 4 processor, you may occasionally encounter game lock-ups or crashes to desktop. In order to solve that, copy your il2_core.dll into the il2_corep4.dll (for example, with the following command: "copy il2_core.dll il2_corep4.dll"; or, in Windows Explorer, navigate to your sim installation directory, delete the existing il2_corep4.dll, make a copy of the il2_core.dll, and rename the copy to il2_corep4.dll)
Special thanks to the third party creators
New Slovak Bf-109 skins - Robert "Robo." Ulbrik, Peter "Foo'bar" Schaller
PAM - Szalai Viktor
*Alis Grave Nil*
Baixando :s:
Mas não falaram nada diretamente sobre o problema principal do Mosquito: velocidade de cágado :evil:
Gutierrez
Post by Gutierrez »
eu acabo de testar o mosquito. Senti o bicho mais estavel e seguro de voar. Pousos agora são sem problemas. a aeronave so mostra mais facil de se manter estavel para vôos a baixa altitude.
Nilton
Post by Nilton »
Que navio é este?
New ground objects:
New ship – PAM (Hungarian) :-? :-? :-?
O Mosquito ainda continua lento, pode ter melhorado a estabilidade, mas a velocidade continua a mesma. :sad:
Fw-190
Post by Fw-190 »
Testei ele aqui e consegui 570Km/h a nivel do mar, suficientes para fugir da maioria dos caças alemães de 1942...
Rasgabucho
Post by Rasgabucho »
Ola pessoal!
eu entri na pag para baixar o update mas lah so tem um update para servidor dedicado.. eh esse mesmo?
vlw pessoal!
Na página tá invertido, o DS com o normal.
Pegue esse http://patches.ubi.com/pacific_fighters/pf_404m.exe
07_Phantom wrote:Na página tá invertido, o DS com o normal.
PH, que dizer que o que aparece na pagina da Ubi como normal na verdade é o Dedicated Server???
Se for, já baixei e instalei :sad:
Será que tem problema? :-?
Parece que sim Condor, mas basta olhar o nome do patch, se tiver DEDICATED SERVER, é ele mesmo
Rasgabucho
vlw gente!!!
