O cartaz "teaser" rudder pedals... com "Joe Brakes".
Bom, pelo menos é nova opção.
- Designed for all users; Compatible on PC with all joysticks on the market; Also compatible on PS4 with the Flight Hotas 4 joystick (sold separately); The first rudder to feature the S.M.A.R.T slide rails system for smooth steering.
- Ergonomic design allowing you to put your entire foot on the pedal, thanks to the heel-rests; Heel-rests are removable, for alternative ergonomic configurations: put your entire foot on the pedal, or rest the ball of your foot at mid-pedal.
- Differential braking: 2 large pedals (10 inches/25 centimeters); S.M.A.R.T (Sliding Motion on Aluminum Rail Tracks) slide rails rudder; System of 4 slide rails crafted of industrial-grade aluminum for perfectly smooth sliding motion.
- Versatile ergonomic design suitable for all types of flight (aerial combat, space adventure, civil flight, etc.); Two differential brake pedals; Large differential brake pedals: 10 inches/25 centimeters (12/45 shoe size).
- USB and/or proprietary RJ12 connectivity; On PC (Windows 10/8/7/Vista/XP), works with all joysticks on the market with available Thrustmaster drivers; On PC, compatible with all games supporting multi-USB and rudders.
Um tiro no pé. Estava lendo as descrições no site da Amazon e já fui direto procurando por hall sensor, mas pelo visto e pelo preço vai potenciômetro mesmo. Uma pena, tendo em vista que a TM coloca hall sensor até nos modelos de entrada atuais dos volantes. Realmente tacaram o F pro pessoal de simulação de vôo. Well, bom pra VKB que vai continuar faturando.O que indica uso de ... pot' - não que usar sensor contactless fosse fazer diferença no preço de custo.
Controle para helicopteros sem chance, e F-18 HOTAS teria poucos botões...They are still deciding which plane/planes to model the HOTAS after addon grips to the Warthog base very likely.
When it came out it was hard to get brick and mortar distributors to go along with the idea of selling stand alone grips, now with online sales/Amazon etc, more feasible
Helicopter collective unlikely. Small market, physically large device.
New rudder will likely accommodate center sticks/giant brass balls.
He stressed that when the new Warthog level Hotas comes out it won't simple be an update of the warthog or cougar, they will incorporate a lot of new technology.
He asked what plane I would like there to be a Hotas for, I said any dcs model, but F-18/F-15 or something with radar elevation rotary.
He said the F-18 didn't have a lot of buttons (I assume they are considering how applicable a stick will be to other planes) but it seems nothing is at set in stone yet.
