"The last flight of Yamamoto"
http://legends-of-aviation.ru/index.php ... -yamamoto/
"In April 1943, the command of the 13 th army USAF, on the basis of decoded Japanese radio communications developed the plan for elimination of Admiral Yamamoto, who was to follow with the inspection, according to the Solomon Islands. As a result of successful operation USAAF, the plane was shot down and Admiral Yamamoto died. "
This event built on the basis of this event, where the option to historical conditions: location, number and type of aircraft on both sides, the approximate rate of repetition, and so on were saved. Retreat from history is the significant reduction in the distance, as the flight time from both sides, and so is high (about one hour or more)
It should be noted immediately that the flight does not wear a sports bias as much flight time, and the complexity of the orientation in the open ocean, is determined as a realistic flight reconstruction, the initial conditions of a historical event.
The fact that more than double the quantitative superiority red team definitely brings more complexity to the complication of the conditions for the victory of the blue, but the presence of the radar of latest, and following the line of the historical ("Lightning" are no more than 100 meters above the water, and have the right to climb only after the visual detection of the enemy) slightly increases the chances of blue.
However, to win the first battle may not mean victory by red team, as a prerequisite, is returning to base, the red and pilots can be intercepted by enemy on the way back.
Game Version:
4.13 without mods.
Server Settings: full-real without speed bar.
Mode: dogfight. In the blue team is present radar with a range of 120 kilometers and altitude range of 100-5000 meters.
Participation in the event by appointment only.
The number of gaming sites is strictly limited to 14 red and 8 blue. In case of absence of one of the players, his place automatically switches to the backup player
Log in to the server with a password, which will be issued at TC before flight.
Planset:
Japan
A6M5 with auxiliary fuel tanks - 6 units + 4 spares on the land Field, and 20 on the aircraft carrier.
G4M1-11 -2 + 2 spare unit.
USAAF
P-38J with auxiliary fuel tanks - 14 units + 6 spares
Details:
