Sokol1- Anti-vulch script now has no warning, if a Red crosses the line his plane should disintegrate immediately.
- Blue spawn points in the bugged little hangers have hopefully all been rendered inoperable with static aircraft.
- Blue spawn points should now allow any squadron markings required.
- RDF bandit messages have been truncated significantly.
- RDF only picks up larger formations, (5+) instead of every single aircraft.
- AI Bomber spawn has been made into a dynamic system which will spawn bigger, but fewer raids the more players are on the server. Under 20 people on the server, the raids should be between 6 and 12 aircraft strong, every 10 minutes. Over 60 players then raids should be BIG (27 aircraft usually) but spawned only every 25 minutes.
- AI Bombers will now target other "non objective" targets as well as Kenley and Biggin Hill. They *may* not be enough to knock the airbases out now.
- Increased the number of AA guns across England.
- Added a couple of barrage balloons.
- Messages referring to a location should now have a grid location included.
- Blues will get 10 minute warning messages for AI bombers with rendezvous & target information, as well as a 5 minute reminder.
- Reduced mission length to 4 hours
CloD™ - London Raide v2
Na rotação do ATAG
Re: CloD™ - London Raide v2
Vixe, e de quanto era antes 10 horas?Reduced mission length to 4 hours
Porque sissy rules só para os red?
Aliás, porque sissy rules?
A idéia destas missões é recriar, na medida do possível um cenário BoB.
Bombers alemães (IA e humanos) atacando alvos na Inglaterra, XX alvos destruidos a Luftwaffe ganha. Bf 109 e 110 escoltando e defendendo os bombers.
RAF atacado os bombers. YY destruidos a RAF ganha.
Acontece que muitos espiritos de porco em Spit/Hurri voam a 30 metros de altura direto para as bases alemães só pensando praticar vulching em quem tenta decolar, ou no ponto de spaw dos bombers...
O oposto tem acontecido muito na Home Plate, o objetivo da Luftwaffe é fechar 3 bases inglesas (depende do peso das bombas lançadas), os ingleses abater 40 aviões.
Ai os "luftwainers" vão chorar no forum que missão é "injusta", que não conseguem ganhar, que não jogam mais, pirirpororó...
Só que os bacanas esquecem de escoltar os bombers, permitindo que cumpram o objetivo e impendindo que a RAF cumpra o seu e vão fazer vulching em Hawking, uns 50 km afastado de onde os bomber devem atacar...
Aí o jeito é apelar para "Radical Rules" - voou para o lugar errado volta a pé.
Outra coisa chata são os "redwhiners" pedindo Blenheim nestas missões (isso quando 5 voam de bomber é muito...), não encaixa no contexto, quer voar de bomber? Muda para a Luftwaffe, oras.
Com certeza, ontem voei essa missão e tinha uns 50 Bfs sobre Wakige esperando que algum spit decolasse, em vez de escoltar os bombers (esquecendo de todas as outras basesSó que os bacanas esquecem de escoltar os bombers, permitindo que cumpram o objetivo e impendindo que a RAF cumpra o seu e vão fazer vulching em Hawking, uns 50 km afastado de onde os bomber devem atacar...
Por isso que se as flaks de curta distância como 40mm, 30mm, 20 e até umas .50 fossem mais efetivas já acabava com essa festa toda.
O objetivo da maioria é colecionar kill, eles gostam mais do estivo War Thunder de ser do que simular fatos históricos.
Mas a partir do momento que se obriga alguém a usar táticas e estratégias para se evitar ser abatido por flaks, por exemplo, a coisa muda de figura.
Não digo que deveriam ser imbatíveis, mas ficar marcando voando em baixa altitude sobre uma base inimiga na WWII é dar muita sopa para o azar.
O pessoal reclamava porque eu atulhava as bases com 20mm e .50 n AW, mas se voce for ver aqueles geradores automaticos de campanha do il2 véio faziam a mesma coisa
