Sua solução definitiva em pedal de leme: MFG Crosswind.
À venda: http://mfg.simundza.com/
http://simhq.com/forum/files/usergals/2 ... t_view.jpg
http://simhq.com/forum/files/usergals/2 ... stment.jpg
Preço estimado de 250 Euros (+frete).Highlits
You are looking at the most advanced and versatile flight simulation gear that ever existed. Art of CNC machining at it's best , made with one purpose – fulfill all simmers rudder need and beyond.
- Built out of sturdy composite material, little aluminium , 17 bearings and all other real industrial parts that are more common on precision machines than it is in any gaming device.
- Unparralled precision, acuracy and feel due to the high resolution contactless magnetic sensors and most advanced pedal centering design
- Highly ergonomic and adjustable in more ways than you can think of
- Can be used for civil, combat and profesional simulation software. Made to be positioned in cocpit and under the table.
- Everything engineered fo long life
- Possibility to mount different foot plates as well as different profiles for centering feel
- 2 years limited* warranty ( limited* by means of spare parts to be assembled by customer)
Features
- Sturdy Composite material construction with some aluminium parts, 17 bearings
- Made by CNC machining to achieve highest acuracy
- 12 bit USB Plug and play controller ( resolution of 4096 positions for all axes). Compatible with Win XP/Vista/7
- Rudder axis : Contactless high acuracy magnetoresistive sensor ; True resolution cca 3800 positions
- Differential Brakes axes : 20 degree of pedal rotation. Reading by hall sensor with resolution of 1000-1300 positions.
- Approved to apply 40 kg of force on each foot plate ( In vertical, horizontal or combined direction. Pedals are tested on lot more, but safety limit is 40 kg)
- Centering spring strenght adjustment, fine tuneable
- 2x positions for centering spring – to achieve stronger or weaker force toward the end of pedal deflection while force near the center remains
- Exchangeable CAM profile to achieve different centering feel. Pedals come with 2x profiles standard.
- Adjustable pedal position from the wall – by adjusting wall spacers
- Four holes for fixing pedals to any base surface
- Adjustable pedals angle from 20 to 52* degree ( if pedals are set to 20 degree and brakes applied than they come to 0 degree. 52* - by raising pedlas from the floor angle of the pedal can be extended up to 62 degree)
- Adjustable 4x different strenght for brakes
- Adjustable foot plates swivel angle toward outside ( watch video)
- Easily replaceable foot plates with different style of foot plates. DIY friendly – you can make your own.
- Pedals include allan key for making adjustments and 2m USB cable for PC connection ( youtube assembly video)
Weight : 4.46 kg ( total with spare cam, usb cable, allan key for adjustments).
Preorder [email protected]
Pedals will be ready for shippment 10-15.08.2013.
Website (coming soon) : mfg.simundza.com
Outros videos no Canal Milan Šimundža.
BTW - Grifon, comprou CH?
