In the arena of our circus - SpeedLink SL-6630 Cougar, in one person has virtually all the possible disadvantages joystick in the terminal stage (except, perhaps, non-linearity of response - other "shoals" simply fail to capture this setting). You can watch a monstrously low sampling frequency axes, hard sewn dead zones in the near-zero positions discrepancy stroke resistors and arms, and in addition - proprietary driver, at times roughened sensitivity (under the standard Windows driver resolution was 256 positions on the axis, but it does had no effect on the absolute impossibility of control of the aircraft). In fairness, I note that I've tested other electronic joysticks SpeedLink although it was far from the standard, but not even close to lying next to this nightmare.
O Black Widow é o 6640, bem melhor em precisão!
