Sokol1Features list version 1.021
GENERAL FEATURES:
1. SPAD 7 in two renditions (early and late) is now available as AI opponent and can be purchased in our store as flyable plane for your account
2. Community Historical Skins Pack vol.8 was approved (+177 new skins)
3. Community Fictional Skins Pack vol.8 was approved (+435 new skins)
4. Official Skins Pack ver.1.021 was approved (+35 new skins)
5. Revised in-game map featuring all new villages, towns and troop encampments.
CAREER FEATURES:
5. Enemy Aces in Career
6. New squadrons from LukeFF ("27th Aero Squadron", "2 Squadron AFC"(thanks to MarcoRossolini for squadron infos!), "19 Squadron", "Escadrille 12", "Escadrille 26", "Escadrille 31", "Escadrille 62", "Escadrille 48"), "46 Squadron" from Tom Cundall, and "92 Squadron" from Reflected
7. Sort by Squadron filter on Career creation screen
8. Sort by Plane filter was added to Career creation screen
9. Mission flight path map visible on Career Postmission->Results screen
10. Old 6 career ranks were replaced by lower 6 ranks, which are unique for each country. Rank emblems were replaced by artwork from von_Fuchs
11. Default speed in sortie flight plan is now dependent on plane type
12. Briefing text now includes sortie pilots assignment list
13. Lone patrol is now available the moment you become CO, even if you're not yet squad commander (a new intermediate milestone for your Career)
GUI FEATURES:
14. Bombsight and simple gauges measurement system can now be set to imperial or metric (or variable according to plane)
15. Aiming helpers can now be turned off separately via widget menu
16. Object icon remains visible on map (slightly grayed-out) after suffering critical damage or running out of fuel
17. User registration errors in game are now more detailed and better commented
18. Deleted missions are now automatically removed from rotation in the Server Creation dialog
OTHER FEATURES:
19. Mission log chunks created while connection to the Master Server is lost are now correctly sent to MS after connection is reestablished (kills/losses during downtime will now be stored)
20. Custom flash dialogs in Multiplayer now accept a wide set of parameters, allowing them to be displayed for a specific plane, player, location and so on
21. Fuel Lock option was added to the list of game server options
Change list of version 1.021
GENERAL CHANGES:
1. Long-term investigation of the "Win7 + 2-core CPU stuttering" issue was resolved, and our code has been optimized accordingly
2. SLI-related stutters were resolved (after NVidia responded to our requests and provided some specific details about their API)
3. Crossfire+HDR blinking issue was fixed
4. Crossfire+AA screenshot issue was fixed
5. Some general optimizations in GUI have significantly reduced gradual performance drop on mission restart
CAREER CHANGES:
6. Two or more major awards can no longer be achieved in a single sortie
7. Fokker D.VIIF skins for Jasta 2 are now properly used in Career
8. Newcomer pilots in a squadron now have similar priority in being assigned as wingman for a sortie as more veteran pilots
9. All reported problems in texts were fixed
10. Forever ballerina on Next Day when user confirms that squadron will be inoperative till the end of War was fixed
11. Forever ballerina on deleting a dead pilot's career was fixed
12. Birthdate in Career biographies now only displays the year
13. All reinforcement pilots are shown in pop-up message
14. A plane which is not compatible with a mission type can no longer be assigned to this mission by default
15. Player starting squad is now correctly noted in pilot's biography
16. Squad and rank of Pfalz D.IIIa kills are noted correctly now
17. Jasta 35b history added
GUI CHANGES:
18. Server name with "=" symbol are now displayed correctly in server list
19. Plane settings in plane Hangar were significantly redesigned, all known issues with plane settings not properly saving between missions were fixed
20. Problem with "Plane is not available" when trying to Fly Out was fixed
21. Fuel Lock, Payload Lock, Skin Lock functions were fixed
22. Some cases of "Forever ballerina" appearing were solved
23. Problem with briefing text which overlapped the menu in Single Mission dialog was solved
24. Problems with bombsight operation while simple gauges are turned on was solved
25. Lock/Unlock button state in Crew Positions turret management dialog now is correct after respawning in Dogfight
26. Incorrect target icons in mission were fixed
27. Game settings like server settings, mission difficultly options, QM settings and so on are now stored on mission start - in case of CTD your settings will not be lost
28. Expanded game map state is stored correctly between missions
29. Icons on/off state is stored correctly between missions
30. All reported typos were corrected
OTHER CHANGES:
31. Nieuport 11.C1 speedometer now shows correct settings
32. Spawned train deletion is no longer causing application crash
33. Nieuport 17.C1 broken animation for damaged wheels on far LODs was corrected
34. Always-open bomb bay doors on far LODs of DFW C.V were corrected
35. See-through holes on damaged Breguet 14.B2 engine cowling were removed
36. S.E.5a Lewis gun trigger wire intersecting with control stick was corrected
37. Airco D.H.2 folded sight is now hidden when raised up back sight is selected
38. Hinges were added to the Bristol's ailerons and elevators
39. Problem in fitting of a strut to upper right wing console on Bristols was fixed
40. Gotha G.V pilot now has a unique model from Elephant
41. Pilots and Gunners 3rd party textures were corrected by Elephant
Links for downloading the Skins Packs: http://riseofflight.com/en/community/usefulmaterials
Finally, we have opened our own torrent tracker for the Rise of Flight version 1.021 installer. You can now download this installer using torrent. We and the whole Rise of Flight community will be most grateful to you if you become a seeder for this torrent.
ROF_FORWEB_1021.exe.torrent: http://riseofflight.com/forum/download/ ... 3c502d1e73
RoF - Patch 1.021
RoF - Patch 1.021
Re: RoF - Patch 1.021
Meu RoF parou de responder desde que atualizei...
Entro em qualquer missão, começa a carregar e nunca começa. Já tentei o "Restore" mas nada também.
Estou pensando em reinstalar, mas também pensando em todas as atalizações que ele baixa depois. Alguém sabe se as outras atualizações estão disponíveis pra download direto como esse patch 1.021 ou só pelo launches do RoF?
Valeu
Matos
Valeu
Matos
Se voce baixar o demo disponibilizado atualmente vai vir já atualizado pelo 1.021.
- 36_Killer-Ants
Download torrent: http://riseofflight.com/Forum/download/ ... p?id=23874Matos wrote:S!
Meu RoF parou de responder desde que atualizei...Entro em qualquer missão, começa a carregar e nunca começa. Já tentei o "Restore" mas nada também.
Valeu
Matos
Lançaram um hotfix para esse patch: http://riseofflight.com/Forum/download/ ... p?id=24805
RE8 ride.
