Algumas boas impressões:Hi everyone,
The beta patch is here.
I want to stress once again that the patch is a BETA. The reason it’s a beta is because we need to test it. If we were sure there were no bugs, we’d be releasing it retail.
The most important change is the new multiplayer GUI. Please test it, and let us know how you like it. A small additional part will be added to it on Friday, which will allow you to switch between the army - player list you see now, and an old-style plane – position list which allows you to quickly switch between available positions a-la Il-2 co-op.
What we’re looking for in this beta is information on any crashes or any other errors you encounter. If you see errors in your console (shift-tab by default) you can enable logging in the game’s conf.ini (set LOG=1 and LOGKEEP=1) and then post any errors encountered along with the brief description of how you got there in
http://forum.1cpublishing.eu/showthread.php?p=300116
Thank you very much for your patience! If everything goes well, we’ll be releasing a more stable more full-featured live version of this patch on Friday.
Download / torrent links:
MegaUpload:
http://www.megaupload.com/?d=GRJ5V5KL
Torrent:
http://www.1cfiles.com/IL2_CliffsofDove ... ar.torrent
"109 Prop pitch works much faster, and the roll-rate is dramatically improved! Elevator trim seems alot more sensitive, will have to adjust my controls, as something definitely changed there, maybe more elevator authority added... "
E outras nem tanto:
"None of the 'add'/'remove'/'save'/'save as' etc buttons in the ammo loadouts work for me at all anymore (they did prior to the patch). "
Aparentemente, por ser o usuário uma toupeira:
"Well I discovered that you have to enter in Options / Plane and modify the loadouts there. Also, you have to select THERE the ones you want to use in the missions. That's quite a strange behavior, however it seems to be finally working. I'd like to be able to select the loadout on the preflight screen though. "
E tem coisas que a ATI continua fazendo para você:
http://img813.imageshack.us/img813/9296 ... 194353.jpg
Online o som continua bugando (pois bugado já é), eventualmente some...
