Beta patch
MadG
Beta patch
Post by MadG »
Re: Beta patch
http://www.flickr.com/photos/61319592@N06/5597890964/
Teste com um track gravado na versão pre-patch.
Bom, pela maioria dos relatos não mudou quase nada - imagino que seja para quem tem máquina High End.
Já este relato com uma máquina "Low End" - com configurações Medium/Low é positivo:
Beta Patch Report
This patch resulted in a significant improvement of the Framerates in my case. The game became totally playable at high settings and smooth at medium settings as enumerated below (video Settings). I can now enjoy the stunning details of IL2 COD Roughly speaking I think the patch easely doubled the Framerates!
My configuration:
Rig:
OS: W7 32 Bits Ultimate (Aero Disabled)
CPU: AMD AthlonII X3 425 (2,7ghz)
GPU: Nvidia GT240
Motherboard: Gigabyte GA-MA78LMT-S2H
Memory: 4BG 1333mhz
HDD: WD 500GB (eco green)
Overclocking: NONE, stock settings
IL2 COD video Settings:
resolution: 1280x800, 59Hz 2x
fullscreen
Object Details: Medium
Damage: Low
Buildings Details: Medium
Buildings Quantity: Low
Ground Details: High
Ground Shadow: Low
Forest: Disabled
Grass: Enabled
Visuel Effects: Low
Shadows: Disabled
Roads: Disabled
At the moment I'm enjoying the sim to much to give a more pertinent bug report but here is 1 small typo and a little bug I came across 10 minutes ago (a futilities really):
1)
- In the French version of the game when you land and brake (using default B key for example) it says:
"Freinage des routes: Activé" "Freinage des routes: Désactivé"
- The message corrected would be:
"Freinage des roues: Activé" "Freinage des roues: Désactivé" (routes = roads | roues = wheels)
2)
- I crashed with a Spitfire, a wing broke off but there was no sound at all when it happened.
Re: Beta patch
O cara está rodando com uma GT240!!! :o
Fiquei até com uma certa esperança depois dessa! :P
Re: Beta patch
O Lutier confirma que os ganhos são mais visiveis em máquinas Low End:
luthier
Senior Member
Hi everyone. Thank you so much for helping us test this patch!
Some additional points:
1. The no-full-screen issue is actually a WIP feature. Until today, CoD only supported a pseudo full screen mode, i.e. a stretched window with no borders. Post-patch we'll have three modes: window, pseudo full screen, and true full screen. We just don't have a GUI switch for it yet, and it can't set it right.
This will be addressed in the live version of the patch.
2. As the patch mainly addressed graphics, the performance gain should have been most noticeable on older machines. The faster your videocard, the less increase in FPS. Eventually your CPU becomes the limiting factor.
3. We do have some additional optimizations that didn't make the beta, like I said. Trees are now a bit faster, and we've optimized block loading, the periodic load-unload of large terrain swatches as you move across the map.
4. If you cannot launch the game, I don't have a fix at this time. We're trying to figure out why this may be happening. Probably a version mismatch somewhere, or it may be connected to the #1 above.
If you wish, you can downgrade to the earlier version by simply right-clicking the game in steam, selecting Properties, and then going to Local Files - Verify Integrity of Local Cache.
And the most important note. If you notice REDUCED performance, crashes, or any kind of other crippling issues, it is extremely important you post your system specs including your version of Windows. That's the only way we can troubleshoot your problem and make sure it disappears by tomorrow!
Com relação a falsa tela cheia usada, alguns jogadores haviam relatado que jogar no modo janela melhorava.
Continua falando de árvores... vai acabar passando o machado até na floresta de Sherwood. :)
MadG
Re: Beta patch
Post by MadG »
Put´z, o Robin vai ficar uma arara! :worried:
Redsoldier
Re: Beta patch
Post by Redsoldier »
A impressão é que eles querem conseguir ter pelo menos esse patch pronto pro lançamento no ocidente...
Ao menos é o que parece.
