HyperLobby 4.0.8
acme313
HyperLobby 4.0.8
Post by acme313 »
Saiu Hoje no site do HyperLobby
Code: Select all
Changes in 4.0.8 (release)
Upgrade note:
    * Datafiles will be automatically imported from 3.9.111 version (friends, ignores, pager messages) if you use this upgrade order:
      1. Close any running instances of HyperLobby
      2. Install new version 4.x (do not change default installation path !)
      3. Uninstall old version 3.x
    * If you uninstall old 3.9.111 before before new 4.x installation you will lose your datafiles !
    * Vista/W7 setup will not run 3.9.111 uninstaller automatically. It is not posible when UAC is enabled. With those operating systems uninstall of old 3.9.111 version must be done manually from "Programs and features" controll panel item.
Whats new:
    * New major version 4 because of some major changes over previous version.
    * Reworked Terms of Service Agreement.
    * Reworked License Agreement.
    * Hyperlobby is now fully compatible with Windows Vista, Windows 7, both 32 and 64bit with UAC enabled. But some games itself may not work correctly with UAC enabled.
    * Dropped support for Windows 98/ME.
    * Any reference to "hyperlobby pro", "hlpro" renamed to "hyperlobby". Pro surfix was used years ago to divide separate products.
    * Datafiles (friends, ignores, pager messages,ini files) has been moved to local user profile folder.
    * Added /e chat commands to edit hyperlobby.ini, /f command to open hyperlobby datafiles folder.
    * Added simple settings editor. It can edit,save,reset to default hyperlobby.ini configuration file.
    * /std and /max chat commands will automatically restart HyperLobby.
    * Maximize/Minimize size of the HL window after doubleclick the titlebar.
    * Added soundmod by Don "Doghouse" Thursby.
    * Added new skin Chrome 1.0 made by Forrest "Thera" Hoffnar.
    * Added new skin Silver 3.0 made by Lucas 'SHARK' Lacher.
    * Added new skin Silver 2.0 made by Lucas 'SHARK' Lacher.
    * Rename forgoten battles room to IL2-Sturmovik 1946.
Bug fixes:
    * Fixed several runtime/installation issues with Vista/Windows 7 operating systems.
    * Skin images are not show (Vista/Windows 7).
    * Application crash after exit (Vista/Windows 7).
    * Unable to close applicatin (Vista/Windows 7).
    * Fixed several issues with games in progress sorting when using "Friends on top" option. Now the games in progress  act like two sorting lists when "Friends on top" option is checked and all the sorting rules applied to both parts,  friends and others.
    * When is the window scale set to incorrect value will be reset to default.Before it causes client failed to start.
    * Fixed widescreen issues when HL is maximized (/max command).
    * Game search dialog now accept path with quotes.
    * Game path locations moved from legacy registry keys to hyperlobby.ini
    * Corrected (hopefully) some language glitches from game search dialog.
    * Removed legacy rogerwilco and battlecom support.
    * Game info settings dialog sometime causes application stop reponding.
    * Removed dexec.exe component (not working in Vista/W7 without extra development effort). For dependency disabled CS1,CFS2,EAW games.
    * Rewrited latency calculation code (ping). External component aping.exe is not needed anymore.
    * Scrolling "games in progress" forgot bump latency calculation timer.
    * New, more accurate ping/picture table:
    * <=25 ms  5 green
    * <=50 ms  4 green
    * <=75 ms  3 green
    * <=100ms 2 green
    * >=100ms 1 green
    * >300ms or timeout  5 red
    * Those values can be adjusted via settings editor.
    * Rewrited network api and removed dependency to mswinsock.ocx library.
    * Mouse wheel scrolled only one line, changed default to 3 (can be configured in hyperlobby.ini).
    * Doubleclick at url in chat or pager containing special characters causes browser open invalid location.
    * URL send by the pager delimited by cr/lf was not openned correctly.
    * Removed anticheat menu. It was not used for years and any current games do not use it.
    * Fixed allmost all user interface handling inconsistences regarding stealing or losting focus to controls (chat,  pager,etc).
Fonte : http://hyperfighter.sk/
Re: HyperLobby 4.0.8
Testado, ok (XPSP3)- salvou e importou até a senha usada na versão anterior.
21_Sokol1 wrote:Testado, ok (XPSP3)- salvou e importou até a senha usada na versão anterior.
Instala por cima?
Meu habito é sempre desinstalar o antigo e limpar o registro...
O instalador pegunta se que desinstalar o anterior - o 4.08 usa outra pasta - depois basta deletar uns restos na pasta do PRO (o antigo).
Se desinstalar primeiro só terá que reconfigurar - usuário, senha, localização do il2fb.exe, etc.
32_Mariocar
Post by 32_Mariocar »
Agora só aparece a versão 4.0.9 para download.
Mariocar
acme313
Post by acme313 »
32_Mariocar wrote:Agora só aparece a versão 4.0.9 para download.
Sera que sai 4.0.9 "m" ? :rofl:
A versão corrente é a 4.09 - corrige um bug encontrado na 4.08.
Testei a instalação no rWin7/64 - não precisei autorizar nada.
Como importou a configuração (usuário, senha, patch...) da versão anterior,
não sei dizer se para localizar o il2fb.exe precisa clicar botão direito e etc...
Conectei num server 4.09m, OK.
BTW- Colocaram o IL2- Sturmovik 1946 como o primeiro na lista de
games, afinal é o único que da quorum (por enquanto...).
32_Mariocar
Sokol, voce sabe aonde fica a lista de amigos. O programa não importou da versão anterior e eu não consegui localizar?
Mariocar
Mario,
Aqui no WinXp importou, no win7 acho que não tinha.
Também não achei, a pasta do HL só contem 4 arquivos
e pasta de Skins.
Também não achei nem na pasta Users nem procurando no
registro...
Encontrei (pelo menos no XP-SP3):
C:\Documents and Settings\User\Dados de aplicativos\HyperLobby
ai tambem ficam o hypperlobby.ini, chatlog.txt.
Edit - No win7/64 fica em C:\Users\User\AppData\Roaming\HyperLobby
A pasta "AppData" (e a Dados do aplicativo no XP) é oculta, portanto tem que mudar as configurações de exibição de pastas para localiza-la.
:P
32_Mariocar
Valeu Sokol!
Mariocar
Corrigiram alguns bugs, a versão atual é a 4.1.2
http://hyperfighter.sk/modules.php?name ... erby=dateA
