Change list 1.010 - 1.011:
NEW/IMPROVED FEATURES:
1. MAIN: Offline General Game Mode added.
2. MAIN: Quick Mission Game Sub-Mode added.
3. MAIN: Fokker D.VIIF fighter added.
4. MAIN: "Hat In The Ring" Campaign added.
5. MAIN: Dynamic Windsocks added to Fly Now missions, Quick Missions and Fast Co-op missions.
6. MAIN: Over-G graphics and sound effects added.
7. MAIN: New Wounding graphics and sound effects added.
8. MAIN: 3rd party skin approving system for MODS OFF game mode added.
9. GRAPHICS: Gamma-correction control added to Settings.exe.
10. GRAPHICS: New optional Bloom post-effect added.
11. GRAPHICS: Optional HDR post-effect added.
12. GRAPHICS: New Rain Drops post-effect added.
13. GRAPHICS: Planes and Vehicles visibility range increased for views with narrow FOV.
14. MULTIPLAYER: System chat messages added (Player connected, Player exited, Player banned, Player kicked, Player pilot killed, Player A shot down Player B).
15. VIEW: "Allow spectators" option completed. Now if it's off, then any user is only able to look from his cockpit or friendly camera operator.
16. PLANE: Mixture and Radiator controlling keys are smoothed.
17. PLANE AI: Planes AI settings are now specified not in code but in config files, so now tuning them is easier for modders.
18. GUI: New design of the Main Menu added.
19. GUI: Mission Options dialog redesigned.
20. GUI: Mission Options presets added.
21. GUI: Logoff function on Main Screen.
22. GUI: Flight Recording settings moved to Options screen.
23. GUI: New design of Hangar Plane Settings window added.
24. GUI: Career screen redesigned.
25. GUI: In-game flight map and chat position, size, opacity now storing.
26. GUI: MG convergence setting storing added.
27. GUI: Chat is accessible from all Pre-Mission screens in Cooperative game mode.
28. GUI: Ships and Trains map icons added.
FIXES/BALANCING:
1. MAIN: Sound-stutters/delays and Sound-related stuttering under Windows 7 was significantly reduced.
2. GRAPHICS: Night reflections on chrome surfaces fixed.
3. GRAPHICS: Moon phase inversion fixed.
4. INPUT: Curves storing bug fixed.
5. INPUT: Mouse sensitivity and mouse Y invert options fixed.
6. VIEW: Camera controls (zoom) stuck fixed.
7. VIEW: Camera should no more "look to nowhere" when deactivated planes are presented in mission.
8. VIEW: Camera operators were fixed - now it can be dynamically deactivated and activated from mission. Selection of camera operator by F12 and LCtrl-F12 now corresponds to coalition(ie. Allies or Central Powers) of the Camera operator. This should greatly help mission modders.
9. PLANE: In case of "start in air", key-controlled Mixture and Radiator no longer drops down on first touch.
10. PLANE: Now in case of "start in air" radiator shutters are in "full open" mode (before is was in "full close" position).
11. PLANE: MG Belts movement now visible when firing (not only when reloading).
12. PLANE AI: Fokker Dr.I often ground-crashing in low-level air combat fixed.
13. PLANE AI: Sopwith Camels often ground-crashing when attacking landed plane fixed.
14. PLANE AI: Sopwith Camels oscillation when attacking landed plane fixed.
15. VEHICLES: Ground units should no longer fire in place where deactivated object was located.
16. VEHICLES: Game crashing when ship receives a waypoint which is located beyond the complex and long river system fixed. Such a complex situation is still not supported by ship's pathfinder, but CTD is fixed.
17. CAREER: Career should now be correctly finishing if squadron plane time of service is over in 1917.
18. STATISTICS: Aerostats should be correctly counted in the post-mission statistics now.
19. STATISTICS: Client's wounding, which was caused by collision, now is shown in post-mission statistics.
20. STATISTICS: Autopilot now not blocking profile statistics.
21. STATISTICS: Plane kill event now happens in the start of plane engine fire. So kill-stealing in this case is now restricted.
22. DSERVER: System logs added.
23. DSERVER: Added missions rotation limit parameter (ShutdownLoads=...), it is temporary solution against DServer crashing after 16..19 like on COCOS server.
Patch 1.011
- 36_Killer-Ants
Patch 1.011
Re: Patch 1.011
Pesou:
http://riseofflight.com/Forum/viewtopic.php?f=49&t=6184
Possível solução (que não comprar um Core I7), usar o tema classico do windows e seguir este guia de tweak:
http://www.escuadron69.net/v20/Un grupo de usuarios, entre los que se encuentra este humilde redactor, están sufriendo problemas relativamente importantes. En el foro de Neoqb se puede leer información de fallos de rendimiento importantes, y CPUs al 100%, con tasas de frames muy bajas. La razón parece estar en algo parecido a tener Windows 7 con un procesador de dos cores, como el Intel Core 2 Duo. No importa qué gráfica se tenga, ni cuánta memoria, si se dan estas dos circunstancias de W7 y Core 2, el simulador puede no rendir como se espera.
Algunas soluciones pasan por tocar el fichero de configuración a mano, y actualmente estamos probando soluciones diversas. Sino, lo de siempre: actualizarse a un procesador de cuatro cores, como el I7, ya que al parecer el simulador ahora requiere mucha más CPU debido precisamente a esas mejoras implementadas. Es el precio que siempre hemos de pagar por tener un software sofisticado, y mucho nos tememos que tendremos que asumirlo, como hemos hecho desde hace años con este tipo de productos tan exigentes con el hardware.
Sokol1Sobre todo lo de poner el Tema Windows Classic para el que tenga W7. Si, es mas feo, pero resulta.. y como...Yo he seguido casi los 8 pasos y ahora va de cine.
http://www.blackviper.com/Windows_7/supertweaks.htm
- 03_Vingador
Re: Patch 1.011
Esta certo isso?? Então você compra um jogo para rodar numa maquina específica e vc é forçado a comprar um processador mais potente ????
Não acho isso correto....
- 36_Killer-Ants
Re: Patch 1.011
Estou rodando sem problemas, mas aqui uso XP...
Talvez em modo de compatibilidade do XP a situação resolva esse problema, caso você esteja enfrentando ele.
