Saitek 45 em Linux ?
43_Scuba
Post by 43_Scuba »
Alguei sabe se tem como usar o Saitek X45 no Linux ?
27_Zylan
Post by 27_Zylan »
Achei este drive genérico na rede
http://www.qbik.ch/usb/devices/showdr.php?id=13
43_Scuba
Post by 43_Scuba »
O Scuba, larga de procurar chifre na cabeça de cavalo... :-P
MaGOid
Post by MaGOid »
O que acontece quando você pluga ele? Ele responde de alguma forma?
43_Scuba
Post by 43_Scuba »
Please :sad: :sad:
Como eu carrego o Saitek X45 no Linux ( openSUSE ) ???
Sei não, mas em todo caso um sujeito escreveu isto:
Configuring your joystick is quite easy :)
Before you start (if you are using Kernel 2.4) you should make the symbolic links for old programs. Since the kernel 2.4 the joystick devices are located in /dev/input and not under /dev like before. To generate the symbolic links perform the following commands:
ln -sf input/js0 /dev/js0
ln -sf input/js1 /dev/js1
ln -sf input/js2 /dev/js2
ln -sf input/js3 /dev/js3
To configure the analoge joystick on the gameport of your soundcard you need a already configured soundcard. I assume you already have this.
Now you need to load the driver-modules for running the joystick:
modprobe joydev
modprobe ns558
modprobe analog
To automatically load the modules at boot-up you can add this 3 lines to your file "/etc/init.d/boot.local":
/sbin/modprobe joydev
/sbin/modprobe ns558
/sbin/modprobe analog
For ISA-PNP Soundcards it is necesarry to initialise the soundcard and the joystick port. This is done by the folowing command:
pnpdump -c > /etc/isapnp.conf
isapnp /etc/isapnp.conf
At next boot the joystick will be automatically inited because the file /etc/isapnp.conf already exists than.
To test your joystick you can use the program jstest:
jstest /dev/js0
It will display the joystick-values (they should change when you move your joystick / press buttons).
To calibrate your joystick you can use the program jscalibrator (/usr/bin/jscalibrator). You will need the package libjsw (serie d) and libjsw-calibrator (serie d).
That is it, now you should be able to use the joystick in games (clanbomber etc...)..
BTW - Outro escreveu: "linux was not made for games like that (Flight Simulators), get windows for games! "
:-P
43_Scuba
Post by 43_Scuba »
:sad: Fiz tudo e nao funcionou :-( :-( :-(
Help Saitek X45 + FlightGear + openSUSE :sad: :-? :cry: :cry: :? :? :?
PS.: os FlightGear e o openSUSE já estao Ok
:D
43_Scuba
Post by 43_Scuba »
X
Eu sou mais
43_Scuba wrote: Eu sou mais
Mas se o X-45 não funciona no Linux, qual o problema em se usar o Windows, Scuba?
Como mesmo citou o Sokol: se for para games, não adianta, o Windows é imbatível :)
43_Scuba
Post by 43_Scuba »
Porque o proximo é o IL-2, só o Saitek é que não quer fucionar direito.
De Windows X Linux , sou mais a favor de 1% linux
Tipo: 80% usa o WV e 1% a Ferrare , qual voce escolhe ????
43_Scuba
Post by 43_Scuba »
Outra coisa
Não tem virus no Linux, Mac OS , Solares, HP, Unix só tem no Windows :twisted:
Outra coisa
Bom, mas como a "Ferrari" não instala o X-45, tem que ficar "pilotando" no teclado... Para o caso um "Fusca" resolveria. Poe os dois ai. ;)
[/quote]
43_Scuba
Post by 43_Scuba »
Só uma coisa ... Sokol1, eu estou brincando viu :-P
É legal ter alguem como você e o Cross
Mas , o openSUSE é melhor :twisted:
:lol: :lol: :lol: :lol:
