Duvida sobre resolução do IL2
Fala galera vamos ver se alguem pode me ajudar.
Tenho o IL2 com um monitor de 19"
alguem sabe se consigo colocar a resolução em 1440x900?
obrigado :-?
obrigado :-?
O IL2 não suporta Widescreen (16:1) nativamente (é de 2001).
Tente com este programa:
http://mission4today.com/index.php?name ... ls&id=2169
- 40_Griffon
Procure na pasta do IL-2 o arquivo conf.ini, abra ele e procure pela linha [window], copie e cole isso ai que eu coloquei que o seu IL-2 ficara em Widescreen, forçado mas vai.
Não se preocupe com as barras laterais que ficaram no menu principal do IL-2, durante o jogo a tela fica normal.
[window]
width=1440
height=900
ColourBits=32
DepthBits=24
StencilBits=8
ChangeScreenRes=0
FullScreen=1
DrawIfNotFocused=0
EnableResize=1
EnableClose=1
SaveAspect=0
Use3Renders=0
[window]
width=1440
height=900
ColourBits=32
DepthBits=24
StencilBits=8
ChangeScreenRes=0
FullScreen=1
DrawIfNotFocused=0
EnableResize=1
EnableClose=1
SaveAspect=0
Use3Renders=0
Segue um mini tutorial...
Fonte: http://mission4today.com/index.php?name ... show&kid=5
E aqui o BearCat explica tb: http://forum.1cpublishing.eu/showthread.php?t=1966
[window]
this describes how windows displays the game on screen
width=1024
resolution width in pixels set in display properties settings tab in windows
height=768
resolution height in pixels set in display properties settings tab in windows
LCD native resolution not included as an option in FB/AEP/PF Enter your screen values here and Save and start your game.... (if you later open the IL-2 Setup and close it by clicking OK it will change the resolution to 640x480 16bit, unless you change it to something else via this IL-2 Setup.) You will need the following values as well
change SaveAspect=0
ChangeScreenRes=1
EnableResize=0
ColourBits=32
resolution colour set in display properties settings tab in windows. Can be 16 or 32
DepthBits=24
Z buffer usage can be 16 or 24
StencilBits=0
Set in driver section of Il2FB hardware setup. Can be 0 or 8
All the above deal with image quality. The higher the numbers for width and height then the more pixels will be used in the same area therefore the image will be more detailed. The larger the number of bits then the more detail there is per pixel so better image quality
ChangeScreenRes=1
allows the screen resolution to be changed in game. Can be 0 or 1
FullScreen=1
forces display to be full screen and not in a window. Can be 0 or 1
DrawIfNotFocused=0
setting to 1 allows watching the IL2 window in the background, while Alt-Tabbing out of the game. Quite useful for playing co-ops - if you crash and wait for the next mission to start, you can put IL-2 in the background and keep an eye on the mission progress, but at the same time start ranting about "my fav plane is porked" on the forums.
EnableResize=0
Enables user to change window size. can be 0 or 1
must be 0 to allow lcds to fill screen
EnableClose=1
SaveAspect=1
Forces 4:3 picture aspect. Can be 0 or 1
Change SaveAspect=1 to SaveAspect=0 will remove some small black bars at the top and bottom of the screen you get without it on lcds
Use3Renders=0
Allows use of up to 3 screens. Can be 0 or 1
Ops, vou aproveitar o tópico em vez de abrir um
Comprei um Samsung 22pol T220, e ando "meio insatisfeito" com a imagem
Mudei a resolução do IL2 para nativa do Samsung (1600x1050, por aí), e abre legal nessa resolução,mas certos detalhes estão uma nhaca: o mar só tem definição de perto, de longe é um borrão de tinta, e qualquer imagem que tenha reflexo, ou com raios de luz, sol, etc, se forma um halo fantasmatico em volta
Alguém já topou com esse problema? :-?
- 32_Mariocar
- Engrenado
