Patch 1.00.14072
Patch 1.00.14072
Atenção que é Beta - teste por conta e risco. :P
Il-2 Sturmovik: Cliffs of Dover: Patch 1.00.14072
Hi everyone,
The beta patch is out. You do not have to install it unless you want to help us test it for issues.
If everything is all right with the patch, the live version of it will hit steam servers late Monday night Moscow time.
Before installing the patch, make sure that your game version is up to date. If you have disabled automatic updates in steam, re-enable it and allow steam to update the game to the most recent version which is 1.00.13954. The game version is shown in the lower right corner of the main interface screen.
The patch will not work with an earlier version of Cliffs of Dover.
Download the patch and manually extract it to your main game directory which by default is
(Program Files)\Steam\steamapps\common\il-2 sturmovik cliffs of dover
Your new game version will be 1.00.14072. This patch will later be overwritten by an automatic update.
Note that while this version will allow you to play online with the older version, they are actually incompatible and you will run into issues. You do not have to report them.
http://www.1cfiles.com/IL2_CliffsofD...2COD_14072.rar
What to look for:
1. Please test the heck out of the new Steam Lobby. NOTE: lobby interface is not yet localized.
2. Changes in performance – please report whether it’s gotten better, and if so, by how much.
3. Any graphical bugs or glitches, especially with landscape, buildings and trees.
4. Any other unforeseen glitches and bugs.
PLEASE keep this thread ONLY for the discussion of the beta patch. Please do not re-report previously reported issues. Please do not use this as a Q&A thread or a flamewar thread or a feature request thread or a lamentation thread. Please keep it purely utilitarian. That’s what this beta patch is – a quick way to see if it does what it should without doing something it shouldn’t.
Thank you all for your support!
NOTE: This is the international version of the patch. It will not work with the Russian version. If you have purchased a Russian version of the game, download this instead:
http://www.1cfiles.com/IL2_CliffsofD...D_14072_ru.rar
Incomplete beta patch readme (the final patch will contain more features):
MULTIPLAYER
* Added a new Steam Lobby feature to the Multiplayer section as an alternative to the existing server search. A lobby is a place for players to gather before joining or creating a server. The most important feature of a Lobby is that it allows one to join servers running on a non-public IP, bypassing network address translation. It will of course also allow you to send players to a public IP server just as well.
When a lobby links to a public IP server, that server can be accessed both from the Lobby, or directly from the Server search. With a non-public IP, the only way to access a server is through a lobby.
When running a dedicated server, the lobby host can link to it by pressing the Find Server button. Otherwise just press Play to create a new Server.
[to be expanded]
* Fixed certain aircraft flame and smoke effects not syncing when playing on-line and recording tracks.
GRAPHICS
* Further improvements to framerate in regards to the terrain engine. It will be most noticeable on machines with 4+ CPU cores.
* SSAO is optional, can be toggled on the fly with a checkbox in Video Options. Turning SSAO off will slightly decrease the graphical quality of the game while improving performance.
* Texture quality slider added to video options. The settings are Original (no change), High (reduced 2x), Medium (reduced 4x) and Low (reduced 8x). Lowering texture size will cause significant performance gain on lower-end machines at the expense of the graphic quality. Please not that the feature is smart enough not to downscale aircraft textures, so the most crucial components of the game will remain unaffected.
AIRCRAFT
* Completely removed overload assessment from carburetters. Rolls-Royce engines will now cut if overload is negative, and will not cut if it is positive. (old values were sneezing at .5G, and cut-out at .25 which we felt were dead on, but this apparently confused most of the players)
* When starting in mid-air, all gyro instruments will be spinned up so you don't have to wait for AH to get in shape, as well as course setters and DI set to actual heading for you.
* Reworked damage module to work dramatically faster when a plane is under heavy bullet bombardment.
* Elevator trim is now set close to neutral when starting in air.
* Returned the water splash when a plane plummets into the water.
* The Spitfire DM will no longer occasionally ignore detached rear fuselage.
* Changed WEP control feedback on Bf. 109. Rather than showing an 'On-Off' message, it now will show if it actually is switched on, and when it actually switches off.
* Fixed minor Bf. 109 damage visuals.
* Ju. 88 gear struts now break off gear well covers when they detach from the plane.
* Fixed missing power cords in Bf. 109 and Hurricane cockpits.
* Fixed visual issue with bullet holes in cockpit glass.
* Fixed issue with FW. 200 radiator flaps floating on detached engines.
* Fixed missing geometry on Spitfire's damaged right wing under the landing flap.
* Reworked movement of the Hurricane boost cut-out pull knob.
* Fixed minor Bf. 110 damage visuals.
* Propellers on detached motors will now appear stalled.
* New spectacular fuel storage explosions (blow up those large round cistern buildings around the map)
* An invisible mental force won't raise your landing flaps on the strip after you start the engine any more.
* Replaced every tachometer in every British and Italian plane with an electrical type, since some people find needle movement on the mechanical type not what they expected.
* Jammed and stuck motors won't budge when flying at high speed.
* Adjusted behavior of broken engines.
* Doubled quantity of air in undercarriage emergency discharge containers. This makes it more likely that your emergency gear will have enough momentum to push the struts down till they lock.
* Landing flaps on Bf. 110 can now be ripped off only as whole, not in halves.
* Bf. 110 hydraulics pump is now driven by its right motor as it should.
* Fixed a bug with carburetor backfire always causing intake damage.
* New assessment causes less initial destruction to surrounding area when fuel storage explodes.
* Fuel storage fires, on the contrary, will be more destructive.
* Flames and heat from aerial fires will now make a plane catch fire, rather than break its parts.
* Implemented new getParameter() to AiAircraft interface to allow more access to aircraft state in mission scripts.
mirrors:
eng:
http://www.megaupload.com/?d=87VANFZS
https://rapidshare.com/files/4575555...COD_14072a.rar
rus:
http://www.megaupload.com/?d=S9FUUZRQ
https://rapidshare.com/files/4575555...D_14072_ru.rar
Torrent:
eng:
http://www.1cfiles.com/IL2_CliffsofD...72.rar.torrent
rus:
http://www.1cfiles.com/IL2_CliffsofD...ru.rar.torrent
capswat
Re: Patch 1.00.14072
Post by capswat »
Opa obrigado pela noticia, testei aqui agora consigo visualizar a lista de servers
consigo conectar em um servidor agora só não sei se é bug ou eu não estou sabendo fazer é selecionar uma base pra iniciar a partida eu vejo o brief o mapa mais nao consigo selecionar base e começar a voar
o Desempenho melhorou tem mais opções no video como SSAO e tals mais não é uma melhora milagrosa
mais pelo menos eles estão trabalhando para melhorar o Simulador
capswat
Post by capswat »
Eita que agora eu consigo dar uma sobrevoada em londres
JOLU
Post by JOLU »
Salve pessoal!
Mesmo capado é um baita jogo, as imagens são belissimas.
Capswat, qual a sua maquina?
Abraço a todos.
JOLU.
Pelo que esta no YT:
GTX 480 - 1920x1080
All High Config AA=0
Phenom X6 1090T
4 GB DDR 3
Windows 7 - 64 Bits
capswat
Post by capswat »
Opa a config é essa mesmo acima porém com 8GB agora
A versão final do Patch já esta no STEAM, como sempre tem gente gostando e gente reclamando... :wasntme:
19_ALPHA
Post by 19_ALPHA »
21_Sokol1 wrote:A versão final do Patch já esta no STEAM, como sempre tem gente gostando e gente reclamando... :wasntme:
Não entendo isso, como assim no Steam? Aqui nem liberado o download foi! =/
19_ALPHA
ALPHA,
Não foi liberado para USA e "restoftheworld", mas foi para a Russia e Europa.
Para que já comprou por aqui, basta dizer a Steam que sua versão é a UK que atualiza.
19_ALPHA
Post by 19_ALPHA »
21_Sokol1 wrote:ALPHA,
Dizer a Steam que é UK, como? Mudar linguagem? :^)
19_ALPHA
19_ALPHA
Post by 19_ALPHA »
Nem tem UK na minha Steam Acc!
19_ALPHA
Redsoldier
Post by Redsoldier »
Mudei a área de download, mas nao é isso pelo jeito... Tb to aguardando resposta.
ALPHA e RedSoldier
Creio que voces estão confundindo baixar Patchs da versão UK através do Steam/USA/Restoftheworld com baixar o Clod comprado do Steam/USA/Restoftheworld - cujo download esta prometido para 24/05 - informando ao Steam que é do UK.
Esta última opção não é possivel, o que o pessoal tem feito é a primeira opção, atualizam o Clod versão UK comprado da Just Flight ou outra softwarehouse da Europa através do Steam/USA/Restoftheworld, neste caso basta fazer isto:
Steam>Settings>Downloads + Cloud>Download Region UK
Redsoldier
Agora sim... Sokol vc nao foi tão direto assim lá em cima!
Fica dando falsas esperanças :rofl:
19_ALPHA
Post by 19_ALPHA »
AAAA!!!!!!! :wasntme: :worried:
19_ALPHA
