LOMAC Flaming Cliffs Install + MODs.
Sydney
Post by Sydney »
Pessoal,
Resolvi documentar a instalação do LOMAC e o Flaming Cliffs, mais as campanhas, mods de cockpit, texturas e muito mais... O simulador ficou outro e estou muito impressionado!
Ai vai meu checklist. Recomendo enfaticamente todos os mods listados:
Baixei a maioria do www.lomacfiles.com - um excelente site.
  • OK Back Up das campanhas velhas/ LOMAC 1.02 e LOMAN 2.1
    OK LOMAC 1,0
    OK Flaming Cliffs serial number
    OK Seasonal Pack
    OK Movies pack
    OK LOCK ON: Flaming Cliffs v. 1.1 - LO 1.1 REG SAVE UNINSTALLER (setupfix)
    OK LOCK ON: Flaming Cliffs v. 1.1 - GROUND UNITS LODs FIX
    OK Reg Saver
    OK HL Lockon (skin)
    OK Zzzspace sound pack V1 for FC 1.1 (instalação manual)
    1. Manually BACKUP the original Flamming Cliffs ‘Sound’ folders, then MANUALLY DELETE EVERY FILE within both the ‘SOUNDS’ and the ‘EFFECTS’ folders - you must remove those files or else the .wav replacements will not work. (Note: wav files are used rather than .ogg for better in-game fps performance)
    2. Download and MANUALLY EXTRACT the downloaded zip file’s contents: zzzspace_v1_for_lomac_flaming_cliffs_manual_instal l.zip This will create the full folder structure path containing all of the relevant files of this sound mod.
    3. Copy and paste the new soundpack’s files into these folders as indicated by their locations by the unzipped folders. When you are done all of the files within both the ‘Sounds’ and the ‘Effects’ folders will have been 100% replaced.
    4. Now place the extracted files into their relevant folders in Flaming Cliffs,
    5. Lastly, make sure that you set your in-game ‘Audio options’ precisely like this (or else you will get other than the intended result – these are not the same as in previous sound packs)
    MASTER VOLUME = 100% (or a setting to balance with multiplay voice comms)
    MUSIC = 25%
    RADIO = 50%
    ENGINES = 100%
    MECHANICALS = 100%
    EFFECTS = 100%
    WIND = 100%
    WARNING = 50%
    COCKPIT = 90%
    OK Instalado o LOMAN 4.0 b3
    OK Instalado os dlls msvr71 e atl71 (senão não funciona - biaxar na net) - A partir daqui todos os instals via LOMAN mesmo.
    OK Lostsoul campaign
    OK Mig-29S campaign
    OK Ukraine Freedon
    OK Red october campaign (1.02 até aqui)
    ok hogsfly
    OK May 0505 Su25t Holdback
    OK SU25T adler campaign
    OK TakeDown
    OK Two Day War mig-29S
    OK OP PHoenix Su-33/Operation Liberty Part 1 e 2/SU-33 Operation Zodiac (descompactado o .RAR e movido para o diretórios de missions/campaigns.
    (each skin has its skin code so you know were they will install - all have been tested and when needed, a new Loman 2.x pack was made)
    Quote:
    MiG-29 Fulcrum web page
    Su-27 Flanker web age
    Su-33 Flanker web page
    F-15 Eagle web page
    A-10 Hog web page
    The Cockpit guide
    the A-10 guide
    OK A-10 Cockpit liftlines by Soul DOWNLOAD IT
    OK+- Blue Cockpit Lights by Mitch Janssen DOWNLOAD IT
    OK+- A-10 Cockpit V.2 BY Archer DOWNLOAD IT
    OK A-10 Cockpit Gauges by Archer DOWNLOAD IT
    OK Kneeboard by Rapier71 DOWNLOAD IT
    OK High Res HUD fonts by Oxyd DOWNLOAD IT
    The F-15
    ok f-15 FULL/RED Cockpit Liftlines by I3eowulf DOWNLOAD IT
    OK F-15 Cockpit by Archer DOWNLOAD IT
    OK Smooth Canopy Frame by Asromzek DOWNLOAD IT
    F-15 Cockpit Gauges by Archer DOWNLOAD IT
    NAO F-15 NVG-style cockpit lights by Merlin DOWNLOAD IT
    OK Smooth HUD Frame by Azromzek DOWNLOAD IT
    (the F-15 uses the same add-ons for HUD fonts and Kneeboard)
    The Fulcrum
    ok MiG-29A/C FULL/RED Cockpit Liftlines by I3eowulf DOWNLOAD IT
    ok MiG-29 Cockpit by Sebastien MHM MHM DOWNLOAD IT
    ok MiG-29 Cockpit Gauges by Archer DOWNLOAD IT
    The Flanker
    OK Su-27 FULL/RED Cockpit liftlines web page by I3eowulf
    OK+- Su-27 Cockpit by Sebastien MHM MHM DOWNLOAD IT
    OK+- Su-27 Cockpit Gauges by Archer DOWNLOAD IT
    And …
    ok High Res US Pilot & Seat by Mitch Janssen DOWNLOAD IT
    ok Cockpit Reflections
Espero que ajude vocês.
Grande abraço,
Sydney
Post by Sydney »
Pessoal,
FIz mais uns MODs... Diria que esse é um dos melhores simuladores que já voei!
  • OK F5 View Info Bar Fix: To fix up the F5 view so that it shows the info for enemy planes and not your own you need to edit an LUA file. Go into the folders Config/View/Server.lua file and make ShowTargetInfo = true In multiplayer your F5 view will be set to whatever the host has set for this.
    OK Clear Green HUD: For a great clear HUD color go to Config\View\view.lua and change your HUD color values to {70, 255, 160}
    OK View Rotation Limit: To extend how far you can see behind yourself go to Config\View\server.lua and edit your: CameraAngleLimits[PlaneIndex.iF_15] = {170.0, -85.0, 140.0}. These are the values I use but you can alter them to suit yourself. Do it for all aircraft you fly. The first number is horizontal, the second is down and the last is up. All are angles in degrees.
    OK Download Russian Headrest Fix: After you increase your range of head movement you might want to fix the headrest with this small install through LOMAN. Read install notes carefully as you have to disable the CDDS feature.
    OK [705]Realistic_Sun_Mod_v2.zip
    OK APR 0205 OVERCAST CLOUD MOD 2.zip
    OK Enhanced FPS Over Water Mod.zip
    OK RealisticMoonV2.zip
    OK StructureLightsV2.zip
    OK skins
    bosshog
    greyfeathers
    greyhog
    russianseat
    OK A10-Su27-33-Weapon-Mod-v11.zip
    OK Lowvisimissiles
    A-10_vs_Shilka-Ironhand.zip
    OK Laser&Optical_Guidance_vs_Shipping.zip (install manual)
    OK Su-25T_Orientation-Ironhand.zip (install manual)
    OK Su-27_vs_F-15.zip
    OK Vikhr_Attack.zip
    OK A-10HighRes-chopper-popper.zip
    OK A10_highres-drkgreen-loman.zip
01_Urubu
Post by 01_Urubu »
TEm alguém animadíssimo por aí.... :)
*Alis Grave Nil*
Sydney
Post by Sydney »
bump pra galera que queira voar LOMAC.
wolfxx
Re: LOMAC Flaming Cliffs Install + MODs.
Post by wolfxx »
O pessoal do EDAV voa o tucano no flamming cliffs uma pena esse mod ser restrito a eles.
