"DCS Dedicated Server Release!
At long last the DCS World Dedicated Server is available to all! In our quest to greatly improve the DCS World online experience, this is a cornerstone element and will play a pivotal role as DCS World Online moves forward. The Dedicated Server is available to anyone that wishes to run one.
Features of the Dedicated Server include:
- Run a server without the need of a render. This allows a server to need less RAM and only a very simple video card.
- The CPU processor load is lower, so you can use a less-powerful CPUs or run more complicated missions instead.
- You can run multiple copies of a Dedicated Server on one PC. Computer capabilities can be used more fully when you start servers in different CPU threads.
- A Dedicated Server can be controlled remotely via WebGUI.
Although we have tested extensively internally and with several community servers, there may be non-official scripts that will not function well with a Dedicated Server. We ask that you report such issues and/or avoid using non-supported scripts."
DCS - DS (Dedicated Server)
Re: DCS - DS (Dedicated Server)
Detalhes operacionais para depois desse último update:
https://forums.eagle.ru/showthread.php? ... ted+Server
O problema é que já estou na segunda tentativa de update
