ATAG's bomber night!
Ou melhor Stuka night. Note que não havera nehuma IA, bem como os 109E-1 serão limitados.
Data a ser anunciada (esta semana).
ATAG_Bliss
Hi fellas,
It's finally time to get a Bomber Night going. The intent of these missions are to have a teamwork / strategic based atmosphere where the team that works the most effectively together and comes up with a good strategy will win. With that said, this will be open to the public, but it is highly suggested you hop on our TS3 (you can see it in my sig) and get tactical.
The mission features 0,zilch,nada, none AI of any kind (air or ground).
The mission is fairly light on the objects as well, in the hopes that can hopefully get over 100 people on and once without any performance problems. It's 1/20th of what we have going on in the main server to give you an idea.
With that said, blues will be attacking and reds defending. There are 4 spread out objectives for blues to bomb all throughout England. Blues will have a 4 hour window to get all the objectives or Reds will win. If Blues win and destroy all the objectives, the map will rotate. Consequently if Reds hold off the blues, after a certain amount of time, reds will successfully win.
This mission will definitely come down to how has the better tactics. I see it coming down to the final objective in a massive engagement, but we'll just have to wait and see ;)
Mission will start Saturday @ 6AM CST (so you Aussies/Kiwi's get the 1st crack at it) and will run throughout the weekend. This mission will be running on our second server, so the 1st one will be unchanged and still available.
Early Planesets:
Reds:
SpitMk1
HurriMk1
Blues:
109E1 (limited to only 15)
G.50
110C7
Stuka
With that said, especially blue pilots, if you've only flown the 109, time to learn some other crates :) I hope to see a bunch of G.50's plowing through!
Here's some screenies to prepare with:
Hopefully this goes off without a hitch. Hope you have fun ;)
Special thanks goes to ATAG_Watchman for making this mission for everyone to enjoy!
This will be posted on our forums as well.
Hora de treinar com o Stuka. :)
Re: ATAG's bomber night!
Data/horário:
Sabado, 18/12/2011 as 6:00AM CST.
Significa uma diferença de + 4 horas, logo as 10:00AM aqui... :worried:
http://wwp.central-standard-time.com/
Será essse o mapa novo que estavam testando? :geek:
Mapa novo? Isso ai é o mapa do Canal default do CloD!
Devido a escala a foto só mostra a "combat zone" (oucoisaqueovalha).
Opa, eu quis dizer missão :P
Tinha uma missão rodando em outro slot que só entra com senha :)
Apesar da choradeira no Banana, "os REDs vão dominar porque so tem E-1 e G-50 "The flying coffin"...
Ou "os Spit com hélices de duas posições não tem chance e etc. etc"...
A BN esta com boa frequencia, mais ou menos meio a meio, e as vezes os Blue com metade de bombers (Ju-87 e Me-110), metade de caças.
Vi ate um G-50 no "roster".
Voei lá tres vezes, a primeira de Stuka, até localizei o alvo, aquelas tres fábricas lado a lado, o gozado foi que asism que vi as fabricas notei que estava voando de "ala" com um Spit.
Fiz duas passagens sobre as fábricas, mas as benditas bombas não desperenderam ou sei la o que...
O Spit me viu, mas por duas vezes consegui despista-lo, na última definitivamente. Durante o RTB a missão acabou por tempo.
No segundo voo de Me-110, sai junto com dois outros caras, cheguei na area do alvo, uma concentração de veículos, mas enquando circulava para acha-lo um Spit me atacou, fui tentar usar
o gunner traseiro - que não fazia nada - e levei um HS... :P
No terceiro vôo sai atrás de outro Stuka e acabei perdendo-o no meio do caminho (acho que cochilei, IRL... :P ).
La pelas tantas o "rádio" informou que o alvo que pretendia atacar havia sido destruido, desvie para um segundo,
e este tambem caiu.
Ficou faltando o mais longe - bombers estacionados na base - mas dei sorte e avistei um monte de pontinhos ao longe,
fui conferir e só uma AAA reagiu. Soltei as bombas a baixa altura (espoletas de 14 s).
Kabum e "Mission Ending".
Blue win. ;)
Quanto tempo durou a "bomber morgning"? :P
Infelizmente, perdi essa :(
A "Bomber Night" dura todo este final de semana (sabado/domingo).
Cada "round" dura 4 horas, se os alvos não forem destruídos os REDS ganham (defenderam).
Ou como no caso que relatei acima termina antes, por terem os BLUES destruidos todos os alvos.
