DCS: October announcement: EDGE 1.5
Re: DCS: October announcement: EDGE 1.5
Os "Bo$ers" que desculpem, mas o DirectX11 realmente faz diferença no engine.
https://www.youtube.com/watch?v=E8JAli3XxGQ[/video]
- 40_Griffon
O jogo está bem mais bonito e bem mais fluido, dentro do cockpit o FPS se mantem a 60, já na visão F2 é que agora que apresenta queda de FPS, era o contrário na versão anterior
As famosas .50cal comedoras de FPS foram arrumadas, ainda não testei as cluster bombs que quando explodiam levavam o FPS a 5
Nada para o Mig-21BUGS...DCS 1.5 Open Beta hotfix 3 (1.5.0.46175.67):
General
‘render3D' option in /Config/autoexec.cfg restored.
Empty ["condition"] variable in mission causes no flyable A/C fixed.
Fixed possible data lost when missions created in old versions saved in 1.5.0.
Advanced Actions panel compatibility with old 1.2.16 missions fixed
Bug with music continues playing when entering training mission is fixed.
Quick Logout fixed
The cloud render in the main menu will not capture PC time in background of the Module manager.
Fixed Unreadable and garbled characters in the MiG-15bis SPECIAL options menu for DE locale.
Some localization updates.
Fixed FPS counter when Oculus Rift used
DX11 crashes fixed
AI
MLRS will move to get valid fire position.
Fixed bug with MLRS wrong fire direction on F10 view.
Multiplayer
Mouse cursor will hide when not in use.
MP chat panel position can be changed by mouse.
Fixed crash to desktop after using backspace key too many times in multiplayer chat.
Fixed bug when some units and buildings were not visible to clients in multiplayer.
Error at the click on server list is fixed.
MiG-29
MiG-29. Cockpit updated.
AoA, Fuel quantity and G indicators updated
UH-1H
UH-1H. Door gunners will engage enemy.
L-39C
L-39. Will possible to assign key for "Throttle - Idle/Stop" action.
Mi-8MTV2
Added clickable controls: flight clock heating, battery heating, emergency and general lighting.
Flashlight added (LAlt+L by default).
MiG-15bis
MiG-15 pilot: G-tolerance increased
F-86
Gun/missile selector switch: cycle clickable fixed
Tô fazendo um upgrade, então vou precisar desabilitar os módulos, aí fiquei na dúvida em qual instalação faço isso... na normal ou na beta?
- 40_Griffon
Da pra fazer por qualquer um, tendo em vista que quando você compra um módulo, você só vai atualizando a versão dele quando sai um DCS novo, então pode fazer isso tanto na atual quanto a na Beta 1.5. Eu desinstalei a versão atual sem desativar e ativei tudo novamente pela Beta 1.5, só estou com ela no PC agora. Se você tiver o Mig-21 e o Bf-109, talvez tenha que dar um bind na sua conta no site da DCS. Basta entrar no site http://www.digitalcombatsimulator.com ai você entra com o seu login e ativa a serial destes dois módulos na sua conta. Tive que fazer isso, pois estes dois módulos comprei via Steam.
Lembre-se de salvar a sua pasta de inputs que se encontra na pasta Jogos Salvos, depois da pra importar os comandos um a um (Warthog, Throttle e Pedais) para os módulos. O único que não funcionou neste esquema foi o Bug-21 por conta dos novos inputs que colocaram.
Mais um update/bug fix para o 1.50
http://forums.eagle.ru/showthread.php?t=147601
E mais uma vez nada para o Mig-21 "BUGS"...
Como esta um drama/novela: "o StarForce comeu outra ativação" do Mig-21...
Antes de instalar, desativei o modulo, baixei o patch (concluiu só na 3a. tentativa), instalado pediu a ativação do Mig-21, concordei e continuam restando 9.
Novo update - com destaque para o Mig-21B'ugs (que provavelmente terá novos "bug's") sistema de ativação e sem alterar a vida dos "virpilovs" HOTAS-FOBO.
DESATIVE o Mig-21 antes de instalar o updated.
DCS: World 1.5.1 Update 2
http://forums.eagle.ru/showpost.php?p=2 ... ostcount=9
DCS World
Encyclopedia. A number of corrections.
Crash when you try take control Su-25, without DRM protection activation is fixed.
Multiplayer chat icon (envelope) can be hidden/unhidden by LCTRL-LSHIFT-Y kombo.
Fixed bug with AI Wingmen colliding with each other while taxiing to the player waiting them on the runway .
The laser rangefinders of russian tanks will paint laser warning sensors during ATGM launch.
Partial fix for ATI R9 3xx videocard.
DCS A-10C
Z-fighting objects on FLIR view are eliminated.
DCS FC3
Added Chinese cockpit textures for Su-27.
Deviation bars on ADI will work in the new MiG-29 cockpit.
MiG-29 rudder pedals animation in the cockpit is corrected.
P-51D
A start on runway with maximum wind crash is fixed.
DCS F-86F
Skin "US AirForce FU-178", corrected tail number texture.
Flaps actuators corrected.
DCS Mi-8MTV-2
Fixed bug with progress of 11th mission Mi-8.
DCS L-39
Corrected the throttle button geometry.
Corrected incockpit pilot’s skin.
DCS MiG-21Bis
Windows Registry entry moved to HKCU/Eagle Dynamics.
All keys have had activations replenished.
Note: It is recommended to manually update and follow these steps:
Cancel any automatic update prompt.
Deactivate module.
Delete all Leatherneck Simulations’ MiG-21Bis Windows Registry entries.
Execute manual update.
Restart Windows, and activate module.
If successful, users should not be asked to reactivate after future updates.
LOD models optimized.
Incorrect ASO texture replaced.
Radome axis of movement fixed.
Double cockpit in low graphic settings fixed.
TacNumbers holes fixed.
Added more variation of Russian TacNumbers
Added Eastern Arabic TacNumbers.
Changed material setting from mirror to aluminum.
Landing gear’s external lights now come on only at full extension.
Remodeled external pilot’s visor and is now transparent with specular.
Navigation lights during the day are now bigger in “Bright” mode.
Missing panel lines and sealant on external canopy/windscreen added.
Missing rivets on right-side drag chute tube added.
Missing screws on top-side wing fuel tank panels added.
UVs for middle fuselage flipped 180 degrees to fix NMp errors.
Liveries adjusted for UV flip.
New normal and specular textures.
Localization
RU localization updated
DE localization updated
Chinese localization added (WIP). There is still much to do.
Note: The Chinese localization is still WIP and a subject to change, so at the moment it has a number of issues with correct Chinese characters displaying. Some parts cannot be displayed in Chinese (now it’s a few elements of the CA interface as well as callsigns). We are sorry for any inconvenience.
DCS World
DCS A-10C
DCS FC3
P-51D
DCS F-86F
DCS Mi-8MTV-2
DCS L-39
DCS MiG-21Bis
Deactivate module.
Localization
Mas que novela esse mig-21, imagina quando sair o F-14, vai uns 3 anos pra ficar bom
Nota: aumentaram o numero de ativações do mig de 10 para 15, e agora sobrou apenas uma desativação
- 40_Griffon
Está mais rápido, pelo menos pra mim baixar o update pela opção de html, o torrente deixei a noite toda baixando e agora as 6 da manhã estava a 2kbp/s, ai cliquei em cancelar e ele deu a opção de puxar direto do link.
Mig-21: "Yes, a lot of model bugs in this update".
- 40_Griffon
Caracas, me fufu com o Mig21. O AirBrake colocaram em um botão só agora para abrir e fechar, sendo que com o TQS Cougar eu tinha a maior boiada usando os dois botões do switch do freio, agora tenho que empurrar e puxar duas vezes para abrir/fechar.. Acho que se eu for lá agora pedir educadamente para arrumarem isso, capaz de me excluírem do fórum.
Bem feito, foi reclamar de muito botão.
Afh, outro "updater baixando, 1.9GB...
Update 1.5.2 - o Mig-21 Bug's segue sem "conserto"...
http://forums.eagle.ru/showpost.php?p=2 ... stcount=10
