VKB Gladiator joystick project
Mensagem por 21_Sokol1 »
The "Bo$$" joystick.
Dear virtual pilots.
Virtual Design Bureau is finalizing a new joystick.
We do this joystick "based on" piston aircraft of World War II. We called this joystick - "Gladiator". Under what name it goes on sale too early to speak.
Why pistons WWII?
1) The market is already joysticks from leading brands, stylized modern combat aircraft.
2) Most virtual pilots to fly it on the pistons.
3) I love piston aircraft of that era, and since the final decision to launch the project to take me, I quickly and without a doubt chose piston design and ergonomics. Here and so took office.
Joystick planned budget. I really hope to see retail prices near $ 70-90. Not expensive. (Price depends strongly on the "greed" of Retail). Prices writing in dollars, as the joystick is made in China.
So characteristics. (Not the fact that the joystick will go into production so as we developed. We are now at the stage of the rendering cost joystick. I admit that some things can be removed or made in the form of additional upgrade. I will keep you informed of any changes) .
Axles - 8.
HAT - 1.
Buttons - 39.
Joystick controller is based on NJoy32. Therefore, the number of axes may be increased by adding a virtual axes. Due to the 3-position switch mods number of virtual buttons can be increased to 111.
Roll, pitch, TWIST - New generation of proximity sensor Mars.
Other axes - potentiometers.
In the joystick encoder is used. Number - 5 pieces.
There will also be an opportunity to connect external pedals and tumbler-keypads.
This is not a "killer sticks" premium segment. Joystick budget imposes many restrictions.
To make quality, but expensive device - just.
Make a cheap, low-quality but - even easier.
But the "sweet spot" - very hard. But we will try.
PS Of course, this is not the final 3D model. We shall now proceed to the rapid prototyping. We are planning to get a workable sample in mid-March. Specificity of production in China - The Chinese New Year begins. In February, few works.
"In the joystick encoder is used. Number - 5 pieces."
Isso ai permitirá trimar com "rotaries" num certo Combat Flight Game. :P :)
Não gostei do desenho "de mesa"*, mas por 80$ esta valendo.
* Na verdade o UIV diz esperar que usem "sobre os joelhos"... sei não não, estes conceitos esta parecendo a estória de XP e unlock...
Re: VKB Gladiator joystick project
Mensagem por 28_Condor »
O X da questão é a qualidade da precisão dos movimentos nos eixos... dá pra dizer algo sobre isso?
O 80 dólares é um bom preço, mas me faz desconfiar da qualidade...
Eletronicamente pode-se dizer que usará o melhor que há em joysticks.
Sensor digital MaRS de terceira geração, 14 bits de resolução, controlador USB Njoy32 USB 2.0.
O X da questão de qualquer joystick é a cruzeta, já que não adianta muito usar um sensor avançado numa cruzeta com folgas,
e esta será de plástico como na maioria dos outros joysticks, aliás baseada no sistema usado no Defender Cobra M5 (projeto VKB),
por sua vez baseada no sistema da CH.
E, para completar tudo isso depende da qualidade da fabricação - que será made in China. :P
Mas pelo menos no papel será melhor do que o que existe nesta faixa de preço.
Falando em cruzetas:
Cruzeta de um Tm Cougar após centenas de horas de vôo.
No inicio dos 2000's este joystick era a "Ferrari" dos joysticks (O WH da epóca).
Típico "Colarinho Inglês". :P
Tenho aqui um CH mais antigo (gameporte) cuja cruzeta esta perfeita.
Furias
Registrado em: 30 Jun 2008 21:00
Mensagem por Furias »
Nada mal, pena que é moldado em peça única - pra quem é canhoto ( como eu) fica muito ruim de usar :( .
T-16000 forever :P
Dependendo do preço compensa comprar só para usar como throttle, removendo a alavanca do joystick. :)
Mais provável que seja o "BoM Joystick". :rofl:
Ganhou um "palm rest" removível.
O primeiro protótipo deve sair este mês e a produção inicar no segundo semestre.
hhttp://forum.il2sturmovik.ru/uploads/monthly_03_2015/post-979-0-83851300-1425620520.jpg
http://forum.il2sturmovik.ru/uploads/mo ... 620583.jpg
http://forum.il2sturmovik.ru/uploads/mo ... 620682.jpg
http://forum.il2sturmovik.ru/uploads/mo ... 620665.jpg
BTW - Compacto desse jeito cabe certinho no rack do Condor. :lol:
O joy não deve valer tanto a pena assim, mas desatarraxa ele e coloca juntinho do THW; o conjunto de botaõzinhos/alavanca é legal :P
Prototipo - visual "do mal". :)
Se o HAT (B-Knopf) for de pressionar são 7 botões no grip.
Lembrando que é um protótipo pre-produção (e as fotos parecem de celular):
Mensagem por 40_Griffon »
Oloco, da até para conectar um cabo de internet nele? :lol:
Seria interessante se fosse possível separar o throttle do stick.
Não, esse conector RJ45 é para conectar o T-Rudder, que tem uma versão mais barata, sem controlar USB, para ser ligado em outros produtos VKB.
Poderia ser também um painel adicional de botões que a VKB planeja.
Furias
Interessante .... pena que parece não haver uma versão para "virpilots" canhotos :(
Se ao menos fosse em 02 módulos independentes dava pra dar um jeito . Ou até se tivesse uma versão simples do joy sem o manete .... &*%$$
Mensagem por 44_Santo »
É que não existiam aviões com controles para canhotos na época. :P
E praticamente nem hoje, os modelos militares monopostos são "destros".
Curiosamente dizem que a quantidade de pilotos canhotos na USAF é maior que destros, os caras tem que se adaptar.
Claro que para jogo é outra estória, não consigo usar nem o mouse na mão esquerda para clicar em alguma coisas nos cockpits. :P
A solução para os "virpilov" é se valer do Tm T.16000M e quadrants da Saitek ou CH, já que servem para "Greek and Trojan".
O HOTAS CH é relativamente "fácil" de MOD'ar (serra, cola...) virando do avesso. :lol:
Furias
Sou canhoto e uso o mouse com a mão direita. Jogo(va) o World of tanks com mão direita ;)
A questão é que acostumei a usar os joys com a mão esquerda. Teria que aprender de novo :lol:
Por outro lado meu bolso agradece já que fico com as opções muitos restritas. Aliás restrita ao t-16000. Mas que seria interessante ter umas opções seria...
