21_Sokol1 wrote:Bem, pelo menos deram um stop na novela FW 190 Under, Yak Uber:
Q= I think Fm is important for this game and players trying to help. Ze_Hairy reported fw 190 climb rate. He did test.
777 = I don't believe we are tweaking FMs for those planes any longer.
Because they apparently don't agree or have time to work on previous planes. Not my call. I just give you the answer.
Essa ladainha é um saco
A verdade é: não sei usar e a culpa é do jogo. Vide Mr. X & cia, tanto faz o avião que usam, o resultado deles é sempre o mesmo , "7x1"
Tenho um amigo que há mais de 20 anos voa de planador. Ele tem o il2 bos é gosta muito dos modelos de vôo. Em especial a decolagem , pouso e taxiamento. Segundo ele está bem feito. Existem discrepâncias, é certo, mas nada tão ruim como estes jejunos tentam fazer acreditar.
Q - Bombs are currently armed when you start your flight, but you can switch them to save. Wouldn't it be more usefull to have them save when you spawn in MP for example.
A - Customers will claim that "guns not firing". We can't.
Ou seja, os "Virpilov Maverick'TriggerHappy" iriam reclamar que o botão do joy ou o Backspace não esta soltando as bombas da "munição infinita" que ele ajustou.
Q - May it be possible to add more keyboard bindings for the bombsight, so that one may fully set it without mouse use?
A - Possible, but we don't want to increase input key map complexity.
Ou o Condor aprende a reconhecer "caminhãozinho" ou...
Q - How about icons, are there any chance to have more options than just on or off?
For example dots only for ground units. No need to display even range, just small dot. Ground targets are hard to find sometimes, it would solve that and at the same time enemy aircraft could surprise me if I`m not checking my six. And full icons take few fps, it would be usefull to people with less powerful hardware.
A- Not planned for a while
Ou vira um "banner hunter".
Q - Is it planned to implement control and axis curves customization like in ROF, with possible settings by planes?
A - No, we don't want to make input mapping system more complex for customer now.
@ Condor, por meros 79,99$ (inclui outros aviões de "brinde").
"The best Soviet ace flying the P-40 in the Red Army Air Force was С. М. Новичков.
By the end of the war in his account was 315 combat missions and 29 victories.
Of these, 19 were won on the P-40 fighters."
LuisF wrote:Well, ao menos a modelagem ficou muito bonita.
Acabei de fazer um rápido teste : o p-40 está redondinho e sem folgas : mergulha e rola bem, e as metralhadoras são potentes. Mais um bela adição para ataque ao solo e com o plus de poder se defender
Fúrias, voce comprou o gold? O dólar estava caindo e subiu de novo... é capaz de fechar em 5 quando cair minha compra
O BoS continua a mesma coisa - com algumas correções de bugs e alguns efeites a mais... e a cabeça do dev's para mudança conceituais: "we have not such plans".
