Defender Cobra M5 e possível solução para os 100throttle.
Re: Defender Cobra M5 e possível solução para os 100throttle
As primeiras unidades já foram vendidas na Russia.
Boa impressão, tem sido reclamado um problema de delay na resposta do eixo Y, mas como os engenheiros da VKB acompanham o forum Sukhoi um novo firmware foi prometido para "two days". :P
Opnião de usuário (GT), considera superior ao TM16.000M (referência entre os "entry-level"):
I've bought so far only RUS (RED is not allowed to go into production) and I must say that vestch definitely a success!
Monolithic device, not squelching, no backlash, no squeaks, no wobbles, etc. Basis heavy that class, and even gum are manufactured on the basis that it had not slipped. The buttons on their seats for an average hand, right under the little finger button is clearly not the cashier. After Logitecha W. Pro - just a fairy tale.
Fly in the Ointment - developed according to the controller sewn into the filter and filter this crap all Pagani, the delay of the response curves at 100% just weird. But at the same spoon of honey - developed in the promised 2-3 days to fix it programkoy. We look forward to.
What cool in all this:
1) Joy is clearly higher than 1600 levels of p. I do this infinitely expected from Logitech exit G940 (which turned out to HS).
2) Direct contact with developers to realtime. After the release of ore (already planned to start now), move to the developed software, and corrected small stocks.
Everyone who has purchased or is going - Wellcome to sabzh.
From a full recommend with a competitor was a more expensive X52 Pro, and the left eye squinting seriously on the stick of the Boar (HOTAS WARHOG). x52 scared of his futuristic, but attract domestic and reputation (all shoals are known and addressed on the forums), Varhog oborzel with the price but from the look I got the same sort of aesthetic naslazhdenie.M5 and not the golden mean, on the contrary, the cheapest of them (even with view unreleased ore), but in terms of total quality and build things - won by a substantial margin.
Lembrando que o modelo não concorre com os HOTAS "high end" (Warthog, X-65, G-940, CH...)
Resultado no Joytester 2, mostrando uma boa linearidade nos eixos X e Y.
Se aparecer por aqui conforme anunciado, vai para a "coleção". :)
MaGOid
Post by MaGOid »
Já estou com bala a agulha. Se sair pelo preço anunciado eu compro uma unidade.
Re: Defender Cobra M5 e possível solução para os "100throttl
Os "ruski" vão ter uma versão exclusiva da VKB, o King Cobra:
Gimbal de metal com rolamentos.
Grip destacável (tipo Cougar/Warthog).
Sem leme g@y (ou possibilidade de travá-lo).
Novo controlador USB (provavelmente o L2 baseado em ATMEGA AT90USB128*)
2 eixos com MarS digital (profundor, aileron)
2 eixos analógicos (pot's) de 10 bits.
4 eixos adicionais podendo ser ligado MaRs ou potênciometros.
32 botões
Firmware atualizável via USBb
Integração com o assento vibratorio da VKB (Force Feedback)
Preço adicional 900 rublos ~28 dolares.
:P
Resumindo, Sokolino vai segurar na cobra, mais cedo ou mais tarde...
:rofl: :rofl: :rofl:
DocFlyer
Post by DocFlyer »
21_Sokol1 wrote:Os "ruski" vão ter uma versão exclusiva da VKB, o King Cobra:
Sokol, procurei mas não encontrei esta notícia.
Tá no fórum http://www.sukhoi.ru ?
Se tiver o link com image, agradeço.
Att.
DOC
Ainda é WiP, em "two weeks" sai as fotos.
Veja o post do UIV no tópico do Cobra.
Prototipo do "King Cobra" - este, não espere encontrar nas lojas locais... :P
Protótipo King Cobra
Base e gimbal (cruzeta) em duralúminio anodizado.
Rolamentos nos eixos X e Y.
2 opções de mola com resistência diferente.
Anel na base do grip permite remove-lo (para eventual substituição por outro modelo),
travar o leme "g@y", ajustar o ângulo horizontal do grip e ajustar a altura do grip em 30mm.
HAT's, gatilhos e botões em metal.
Grip emborrachado.
Base pode ser usada como upgrate do Cobra M5.
DocFlyer
Post by DocFlyer »
r um mecanismo durável no caixa do "Hotas Cougar".
Doutor, me desculpe, mas upgrate para o Cougar existe a uns 10 anos, é de metal, feito em CNC, usa rolamentos, mola substituível: chama-se UberNXT. A não ser uma eventual mola quebrada nunca vi ninquem reclamar da durabilidade.
Acompanhei as discussões sobre a criação destes MODS para Cougar no finado Frugals desde que foi lançado - na epóca até pensei em comprar um, mas cheguei a conclusão que não valia a pena (custo/benefício), principalmente porque o "bendito" grip de F-16 é bom para F-16, mas para quem usa POV HAT para visão e prefere sim WWII é um saco!
Curiosidade: no mercado local espera encontrar quantos Cougar para receber upgrate?
BTW - A WKB criou um kit para upgrate de Cougar na Russia, mas desistiu de produzir porque não a mercado - lá - que justificasse.
DocFlyer
Post by DocFlyer »
Ai está bem evidente o problema de tentar adaptar um mecanismo durável no caixa do "Hotas Cougar".
A solução projetada pela WKB, que não exige nenhuma modificação para caber na caixa do bendito Cougar:
Segundo o UIV da WKB, produzir - para vender para os poucos donos de Cougar na Russia (que devem ser mais que no Brasil) seria "Невыгодно" ~ Unprofitable ~ Não lucrativo...
E, não sou "expert" em coisa nenhuma! Mas tambem não sou desinformado a ponto de "comprar" esta idéia de que nunca criaram solução viável para Cougar. Até com madeira já refizeram o gimbal da "maravilha" (Trolbug da França) possivelmente funcionando melhor que o original, desconheço se deu cupim...
BTW - Convenhamos que falar de Cougar neste tópico é descaracteriza-lo, já que a proposta aqui é um joystick acessível - o que o Cougar nunca foi - com algum diferencial de qualidade. A tópicos mais apropriados.
Desculpem a minha ignorância, mas se a pessoa vai aproveitar apenas a carcaça do tal "tão bom" Cougar, então seira melhor comprar um "ching ling" qualquer e transformar num super joystick.
Na verdade não sobrou muita coisa do Cougar com todas essas modificações, melhor ainda é fazer um projeto do zero igual ao do Tchê.
Acho que a carcaça é o menos importante num joystick, tem gente por aí que nem carcaça usa. :P :D
DocFlyer
Post by DocFlyer »
Caro Cmte.
a propósito (BTW)... também não concordo em descaracterizar os tópicos, mesmo que isso tenha sido feito 8 vezes num único tópico que abrí. Também me enganei, pela minha desinformação comprada através de entusiastas e uma dezena de MODs e Críticas, que demonstram que cada qual via uma solução para o apreciado e problemático HC.
Quando me inscrevi no site concordei com o termo em manter: O respeito mútuo, colaboração e diversão.
Mesmo chamado de "doutor" levo na brincadeira e realmente lhe considero um "expert" na área. Sem "puxasaquismo".
Peço desculpas se fui sarcástico. Também peço que há modos e modos de discutirmos ou até uma MP, avisando de algo que eu possa ter escrito, sobre um ponto de vista. Não piloto há 5 anos e não vivo comercialmente da simulação. Gostaria até de ter mais tempo para me aprofundar, mas tenho trabalhado muito.
Os anos passaram e muitos já não frequentam o site. Por este motivo empresto um monte de coisas e estimulo até alunos a se interessarem pela simulação.
Bem, passado o conflito de cabine...
Peço sinceramente desculpas, e se achar de bom tom apagamos estes posts e mantemos o foco do tópico.
Att. DocFlyer
Controlador USB, placa de expansão (até 128 botões) e software de aualização do firmware. O cabo de interface entre o controlador e a placa de expansão tem 2 metros, flexibilizando a localização da mesma.
Versão para montagem central a la Warthog.
