Upgrade do projeto de Joystick D.I.Y. (homemade).
Re: Upgrade do projeto de Joystick D.I.Y. (homemade).
Essa re-enumeração depende do Windows - comum do Win10 - e do jogo - comum no RoF e BoS.
Do ponto de vista prático não a o que fazer para evitar. Como quebra galho salve as configurações dos dois jeitos e alterne conforme mudar.
Em todo caso veja se o JoyID ajuda - pelo menos para identificar qual é o Joy1, etc... : http://theairtacticalassaultgroup.com/f ... hp?t=13009
Alguns sugere isso, desplugue e desinstale todos os joysticks, limpe as referências no Registro.
Renicie o computador, plugue e assim que instalar reinicie. Então faça as configurações - e salve os arquivos de "config" dos jogos.
Posição da CH Products:
"Sadly, we have no control over the Windows boot sequence since our USB products are plug and play devices. However, I have heard of a workaround within the optional Control Manager software we offer, and received feedback from users that remedied the problem by installing the Control Manager and creating a profile or a map.
We did some testing today with our engineers and confirmed that the Control Manager has nothing to do with this issue.
We plugged in 3 different units and confirmed that the order matched the order that they were attached, and once rebooted we confirmed that Windows 8 and 10 did in fact change the order in the Game Controllers menu.
However, once the computer has been rebooted once, the order sequence that Windows generated stays the same even after rebooting multiple times."
So, the steps would be to plug the units in, reboot, and then assign the products. I recommend trying this yourself to see if it helps."
DHRF
Post by DHRF »
For usb use this tool
http://www.nirsoft.net/utils/usb_devices_view.html
I will show all usb information and has the capacity to fix/clear errors
Tche-Loko, o cara ai usou pedal de biclicleta no "T-Rudder" clone:
41_Tche-Loko
Post by 41_Tche-Loko »
A criatividade é o limite.
41_Tche-Loko
Buenas!
Resolvi fazer um novo Upgrade. Trocarei a cruzeta de barra de direção por um sistema baseado no VKB Gunfighter MK.I.
Achei está cantoneira em alumínio no ferro velho.
Comecei recortando as peças.
Já começou a pegar forma.
Tche_Loko
O que acha de experimentar com CAM?
Gimbal impresso em 3D - plástico.
http://i.imgur.com/ePbzeG9.jpg
Não entendi o porque da mola nesta posição, dobrando... Talvez para manter o conjunto compacto...
Estes profiles são para o Warthog - o desenho do Y tem a curvatura de forma a compensar a tendência de queda para frente do grip (pesa quase 1 kilo) e não deve ser útil para outros joy'.
https://youtu.be/GYEHeTIXiQ8
https://youtu.be/e6rJbj_rtJY
O perfil para X poderia ser usado também para o Y em experimentação.
As alavancas poderiam ser impressas em 3D, a Shapeways imprime inclusive em aço.
O autor disse que talvez faça um software para automatizar o cálculo da curvatura da CAM, que neste tipo tem que ser assimétrica.
No sistema usado pelo BAUR, com duas alavancas, o perfil é igual nos dois lados.
41_Tche-Loko
A ideia era usar este sistema agora com esse modelo em preto que você postou Sokol1 vai me facilitar a vida.
Algumas fotos de como tá ficando.
41_Tche-Loko
Furação e aberto o rasgo para o rolamento.
41_Tche-Loko
Sokol1!
Gostaria de saber a sua opinião a respeito de utilizar amortecedor no lugar de só mola.
Tche_loko,
Amortecedor nunca vi usaram, só Damper, no caso da base do (RiP) Tarmac Aces.
O Damper não comprime o fluído, mas força de um lado a outro de uma camera através de penos orifícios.
Mas veja o resultado na prática. :)
41_Tche-Loko
Amortecedor é muito mais complexo, possui valvuladas, furos diferenciados. Dendro desta classificação utilizarei damper com mola (automodelo). O manche anterior já possuía damper porem não era muito efetivo na centralização.
A ideia de utilizar o damper e não ter aquele efeito de ao puxar o manche e soltar ele ficar com o efeito pendulo.
Isso mesmo e no caso de joy para helicoptero que não precisa voltar ao centro o damper funciona bem.
O que usar para serrar esse alumínio espesso deste jeito ~1/4?
41_Tche-Loko
O alumínio é de 1/4", usei furadeira, serra manual e lima. No começo usei serra fita com a serra pra madeira e acabei quebrando e foi dai pra diante com serra manual mesmo.
41_Tche-Loko
Desmontagem para rebitar o suporte do dump. Furação para instalação dos parafuso que irá fixar as duas partes.
Instalação do dump. Falta chegar os rolamentos do braço para substituir o rebite que esta provisoriamente como eixo.
41_Tche-Loko
Prefiro o acabamento em aço inox, porem, aqui no sul faz frio e congela as mãos. Vou mudar para madeira.
Adicionei os três casulos para os potenciômetros. Optei deixar os eixos e botões mais a mão.
O gimbal está praticamente pronto. Falta fixar uma ponta do dump e instalar os sensores hall.
